Windows 10 : raccourcis clavier avec la touche Windows
A remercié : 170 fois
A été remercié : 946 fois
Microsoft propose un guide des raccourcis clavier pour son système d'exploitation Windows 10. Des raccourcis avec la touche Windows pour améliorer la productivité.
Windows key  	Open and close the Start menu.
 +1,  +2, etc.	Switch to the desktop and launch the nth application in the taskbar. For example,  +1 launches whichever application is first in the list, numbered from left to right.
 +A	Open the action center.
 +B	Highlight the notification area.
 +C	Launch Cortana into listening mode.  Users can begin to speak to Cortana immediately.
 +D	Switch between Show Desktop (hides/shows any applications and other windows) and the previous state.
 +E	Switch to the desktop and launch File Explorer with the Quick Access tab displayed.
 +H	Open the Share   charm.
 +I	Open the Settings   app.
 +K	Open the Connect pane to connect to wireless displays and audio devices.
 +L	Lock the device and go to the Lock screen.
 +M	Switch to the desktop and minimize all open windows.
 +O	Lock device orientation.
 +P	Open the Project pane to search and connect to external displays and projectors.
 +R	Display the Run dialog box.
 +S	Launch Cortana.  Users can begin to type a query immediately.
 +T	Cycle through the apps on the taskbar.
 +U	Launch the Ease of Access Center.
 +V	Cycle through notifications.
 +X	Open the advanced menu in the lower-left corner of the screen.
 +Z	Open the app-specific command bar.
 +ENTER	Launch Narrator.
 +SPACEBAR	Switch input language and keyboard layout.
 +TAB	Open Task view.
 +,	Peek at the desktop.
 +Plus Sign	Zoom in.
 +Minus Sign	Zoom out.
 +ESCAPE	Close Magnifier.
 +LEFT ARROW	Dock the active window to the left half of the monitor.
 +RIGHT ARROW	Dock the active window to the right half of the monitor.
 +UP ARROW	Maximize the active window vertically and horizontally.
 +DOWN ARROW	Restore or minimize the active window.
 +SHIFT+UP ARROW	Maximize the active window vertically, maintaining the current width.
 +SHIFT+
DOWN ARROW	Restore or minimize the active window vertically, maintaining the current width.
 +SHIFT+LEFT ARROW	With multiple monitors, move the active window to the monitor on the left.
 +SHIFT+RIGHT ARROW	With multiple monitors, move the active window to the monitor on the right.
 +HOME	Minimize all nonactive windows; restore on second keystroke.
 +PRNT SCRN	Take a picture of the screen and place it in the Computer>Pictures>Screenshots folder.
 +CTRL+LEFT/RIGHT arrow	Switch to the next or previous virtual desktop.
 +CTRL+D	Create a new virtual desktop.
 +CTRL+F4	Close the current virtual desktop.
 +?	Launch the Windows Feedback App.
vous pouvez allez consulter ce document ICI : https://www.microsoft.com/en-us/downloa ... x?id=48716
Merci a GNT
A été remercié : 8 fois
Re: Windows 10 : raccourcis clavier avec la touche Windows
Merci chtimi,
J'ai modifié ton post pour donner le lien direct vers le tuto Microsoft,
Après faudrait traduire tout ça, mais en effet c'est intéressant :)
jecontrole
Visiteurs
Visiteurs
Message par jecontrole »
une peut Pour les raccourcis clavier traduit en parti chtimi
Windows + flèche du haut : maximiser la fenêtre
Windows + flèche du bas : rabattre la fenêtre dans la barre des tâches
Windows + flèche gauche/droite : la fenêtre occupe la moitié gauche ou droite de l’écran, et se déplace
Windows + flèche gauche/droite, puis haut ou bas : la fenêtre occupe la moitié de l’écran puis le quart
Passons ensuite aux raccourcis vers les fonctionnalités principales :
Windows + A : ouvrir le centre de notifications
Windows + S : ouvrir Cortana en mode saisie (recherche classique au clavier)
Windows + Q : ouvrir Cortana en mode écoute (requête vocale)
Windows + I : ouvrir le centre de paramètres
Windows + L : verrouiller la machine ou changer d'utilisateur
Windows + R : lancer une commande
Windows + E : lancer l'explorateur
Windows + D : rabat toutes les fenêtres dans la barre des tâches. Refaire le raccourci les remet en place
Windows + Impr écran : enregistre une capture de l'écran dans le dossier Captures d'écran du répertoire Images
Windows + Tab : Afficher les tâches en cours (Task View) et l'interface de gestion des bureaux virtuels
Alt + Tab : afficher les tâches en cours avec la vue classique
Des raccourcis spécifiques ont par ailleurs été ajoutés pour contrôler spécifiquement les nouveaux bureaux virtuels :
Windows + Ctrl + D : crée un nouveau bureau virtuel
Windows + Ctrl + flèche gauche/droite : permet de se déplacer au sein des bureaux virtuels
Windows + Ctrl + F4 : ferme le bureau virtuel en cours d’utilisation
