firefox v22 ne fonctionne plus sous Emmabuntüs 2
Vos soucis avec le pingouin...
Re: firefox v22 ne fonctionne plus sous Emmabuntüs 2
voilà le résultat de la commande :
Package: skype
Version: 4.2.0.11-1
Architecture: i386
Depends: libasound2 (>= 1.0.23), libc6 (>= 2.3.6-6~), libc6 (>= 2.7), libgcc1 (>= 1:4.1.1), libqt4-dbus (>= 4:4.5.3), libqt4-network (>= 4:4.8.0), libqt4-xml (>= 4:4.5.3), libqtcore4 (>= 4:4.7.0~beta1), libqtgui4 (>= 4:4.8.0), libqtwebkit4 (>= 2.2~2011week36), libstdc++6 (>= 4.6), libx11-6, libxext6, libxss1, libxv1, libssl1.0.0
Recommends: sni-qt, libasound2-plugins
Conflicts: skype-mid, skype-common, skype-bin
Replaces: skype-mid, skype-common, skype-bin
Installed-Size: 38248
Maintainer: Skype Technologies <info@skype.net>
Priority: extra
Section: non-free/net
Filename: pool/import/s/skype/skype_4.2.0.11-1_i386.deb
SHA256: 7ffaa8537a4bf4b71860feeebd32539998c9450c561daa3e7535f098d521c3cc
SHA1: 0d6abcfcfb5cf378a310ae87cb4bfc46c6c66382
MD5sum: 927de96176ee01c03f53c5975b628e4f
Description: Wherever you are, wherever they are
 Skype keeps you together. Call, see, message and share with others.
  * It's free to download and join.
  * Call, instant message and send photos and documents to anyone else on Skype.
  * And with a webcam you can catch up face-to-face with a video call.
  * Call mobiles and landlines worldwide at low rates.
  * Easily text message anywhere in the world.
  * Get your friends together on a conference call.
 And that's just the start...
Package: skype
Priority: extra
Section: net
Installed-Size: 61
Maintainer: Steve Langasek <steve.langasek@canonical.com>
Architecture: i386
Version: 4.2.0.11-0ubuntu0.12.04.1
Depends: skype-bin
Filename: pool/partner/s/skype/skype_4.2.0.11-0ubuntu0.12.04.1_i386.deb
MD5sum: 77359141450a4acddac04e29696ba04d
SHA1: 23f02fda03a67c922aa6311d08aac8b74752bc22
Description: client for Skype VOIP and instant messaging service
 Skype is software that enables the world's conversations.  Millions of
 individuals and businesses use Skype to make free video and voice calls,
 send instant messages and share files with other Skype users.  Every day,
 people also use Skype to make low-cost calls to landlines and mobiles.
 * Make free Skype-to-Skype calls to anyone else, anywhere in the world.
 * Call to landlines and mobiles at great rates.
 * Group chat with up to 200 people or conference call with up to 25 others.
 * Free to download.
J'ai réinstallé avec ce que tu m'as donné et après ouverture du Gestionnaire de MAJ le paquet "fantôme" n'a plus l'air d'y être!!! merci :) :) :) :)
Je te tiens au courant si ça revient ou pas
concernant mon probl réseau chez moi, je n'arrive pas à modifier le fichier que tu me demandes de modifier j'en ai pas les droits soit disant.. et impossible de les changer... idem pour faire la sauvegarde du fichier de config
idéfix
Message par idéfix »
as-tu déjà essayé la commande ifconfig dans un terminal, pour voir si tu obtiens une adresse IP ?
exemple :
résultat correct pour les lignes eth0 ou wlan0 : inet adr: 192.168.175.10 Bcast:192.168.175.255 Masque:255.255.255.0
si pas d'adresse résultat incorrect : inet adr:127.0.0.1 Masque:255.0.0.0
AigletoN
Message par AigletoN »
Pour modifier le fichier tu doit etre en root soit
Sudo et la commande
Ou
Su
Le mot de passe te sera demandé
Edit :
connaissant pas ton matériel ,pense à essayer clé wep ,surtout si au taf c est du wep. certain matos supporte pas le wpa
alors résultat de ifconfig au taff :
wlan0    Link encap:Ethernet  HWaddr 00:22:fa:06:4d:3c
            inet adr:162.38.27.49  Bcast:162.38.27.255  Masque:255.255.252.0
            adr inet6: fe80::222:faff:fe06:4d3c/64 Scope:Lien
            UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
            Packets reçus:10151 erreurs:0 :0 overruns:0 frame:0
            TX packets:4294 errors:0 dropped:0 overruns:0 carrier:0
            collisions:0 lg file transmission:1000
            Octets reçus:10582068 (10.5 MB) Octets transmis:812959 (812.9 KB)
et chez moi où ça ne marche pas :
            inet adr:192.168.1.12  Bcast:192.168.1.255  Masque:255.255.255.0
            Packets reçus:113 erreurs:0 :0 overruns:0 frame:0
            TX packets:126 errors:0 dropped:0 overruns:0 carrier:0
            Octets reçus:25699 (25.6 KB) Octets transmis:24494 (24.4 KB)
j'ai fait tes manip en root Aigleton (je suis vraiment trop laid de pas y avoir pensé), et malheureusement aucun changement :(
AigletoN
Pour acceder a ta box tu passe par http://192.168.1.1" onclick="window.open(this.href);return false; si non remplace gateaway par l'ip dont tu accede.
Au niveau des clés tu accede au taf par cle wep ou wpa ? Tenter le meme type de chiffrage.
Tu detect ta borne au moins ? Loll
c'est sans clé
c'est le WIFI de l'université, tout le monde peut se co mais il faut des id pour valider par navigateur, comme les bornes WIFI publiques en somme
ouais je SUIS connecté, je capte à fond mais LES NAVIGATEURS PATINENT DANS LA SEMOULE :envy: :envy: :envy: :rofl:
AigletoN
Navigateur.
Histoire d etre sur ta deja essayer de telecharger en console avec wget .voir deja si juste navigayeur.
ok j'essayerai
idéfix
Pour savoir si le problème est dans les logiciels installés sur ta machine ou pas,
pourrais-tu essayer une session live cd ou live usb avec une autre distribution,
par exemple toutoulinux ou bien asri edu version profs http://sourceforge.net/projects/asriedu ... ylucid528/
ou bien une autre légère que tu as sous la main ?
