[TUTO] Folding@Home v7 Client Beta Release
- Prof
- Fondateur
- A remercié : 4 fois
- A été remercié : 14 fois
Re: [TUTO] Folding@Home v7 Client Beta Release
Ok merci,
Non je n'avais pas vu... mais bon des wu j'en ai déjà 200 non ?? Ou c'est 10 avec ce client ?
c'est 10 en SMP avec un client SMP le dernier ou pas.
>> UPDATE <<
FAHClient v7.1.24 released !
Win 7 64bit - Direct Download
Download page autres OS
Il est fortement conseillé de finir tout WU avant de mettre à jour !. Attention de ne pas effacer votre dossier "DATA" !.
Cliquer sur l'icone "Finish" pour finir tous les WU.
Changelog:
v7.1.24
v7.1.22
Changelog:v7.1.24
v7.1.23Don't download a new WU if max-units is reached. #607
Added GeForce GTX 460 SE to the white-list.
Fixed 'core-priority' in FAHControl.
Fixed options save.
Don't allow changing 'local' client name or IP.
Don't try to autostart the local client once online.
Fix permissions problem in RPM. #627
Hide 'Status' tab in novice mode.
Added project info. In novice mode only by default.
.Fixed bug caused by ignoring WU return code after a quick pause/unpause.
Set default verbosity to 3.
Explictly white-list Fermi GPUs & downgrade if CUDA driver is insufficient.
Added new GTX 470, 485 and 590 to GPU white-list.
Moved FAHControl single app port within 0-65535 range. #604.
Filtered out 'Theater' from GPU list.
White-listed Nvidia Quadro G8x cards.
Move all ATI R700s GPUs to species 3 and R800s to species 4.
Don't allow passwordless access even if password is not set.
Don't automatically allow IPs in command-allow-no-pass.
Don't call battery status code if not necessary.
Release resources related to battery query in OSX. #593
Allow changing the number of CPU threads mid run but warn. #292
Fixed client new and client connection options saving. #617
Lock database on startup to stop multiple runs of FAHClient in same dir.
Pass '-service' option to core when running as a Win32 service. #592
Fix permissions for All Users Windows install. #595
v7.1.22
Added proxy support with authentication types: none, basic & digest.
Added proxy configuration tab to FAHControl.
- Prof
- Fondateur
Bouhlol
- Visiteur
oOZz: pour le réseaux, sa marche avec des IP dynamique ??
- dandine78
- Visiteur
bon bas on va sy remettre
aymeric81401
- Visiteur
>> UPDATE <<
Modification du Topic:
Ajout du point 2. d) : paramètre max-packet-size : big
Modification du point 5. : Le flag beta n'ets plus valable dans cette nouvelle version. à remplacer par le flag: advanced
FAHClient v7.1.52 released !
Téléchargements
Téléchargements
Spoiler : Changelog: :
elgayer
- Visiteur
Bonjour a tous, j'ai une carte graphique nvidia gt 620 et je voudrai "l'enregistré" mais lorsque je fait "add gpu" j'ai un message d'erreur..
quelqu'un peut m'aider?^^
Sûrement une histoire de pilote...
ou d'incompatibilité, à voir sur f@h.
